Cross over Centre channel at 80 Hz? Looking at Emotiva XRC 6.2
twoeyedbob
Question is...what du you think ?
Sent from my HTC Vision using Tapatalk 2
Jmoi3
Well I won't know because I'm still waiting for thier arrival. I still have the acoustimass 5s and 3s for sale. Hopefuly I could get 200 for the two.
Jmoi3
So I put myself in another pickle.... I got the Energy RC-10s, which are GREaT!! And a Polk PSW10.. I wanted a center and on a tight budget did a dumb impulse purchase and got a Energy Veritas V-Mini-C.. 2 Way.. It says that it goes down to 78hz, I'm not sure it really does. I need a recomendation on the crossovers please. Thanks
twoeyedbob
If it says it goes to 78hz,,then 100hz..or possibly (at a push)90hz..
80 would be far to close to the limits of the speaker
Mine go to 50hz....crossover at 80hz...i'd try 70
If the receiver would let me...80's probably best though
Someone with a better audio vocabulary will be along in a min ...;-)
Jmoi3
So I set it to 90hz.. I was calibrating using my spl to 75. Exited my GUI menu before lowering the volume.. I think I almost lost my hearing, it was only for about 20 secs.. But man I was REALLY worried about blowing my speakers. How would I be able to tell ?
twoeyedbob
It'll make funny noises
Jmoi3
I was wondering if after my calibration should I higher the center to about two DB higher than the rest ?
twoeyedbob
Use your test tones and your meter....then
Fine tune it by ear over a few weeks over a variety of
Sources...personally, i find myself using sky
Careful with the centre as it's obviously smaller than the rest
