Thanks J Garcia! I'm from Northern Ireland so i don't know if there would be a specific marantz dealer but as I say I was just put off going there paying for the tech person to look at it and then for them to say it will cost £150 to fix etc but i guess then i would definitely know for sure instead of always wondering. But when you talk about a "bad component" is there any chance you know how much this issue would cost roughly to fix? It would just be good to know if this is a relatively small/simple job for a technician to do
I actually telephoned up Marantz a few days ago to see if this was a common problem and to see if maybe they knew what needed to be fixed exactly. When i explained the problem the woman gave me a number, so i assumed that this number was say for a different line that dealt with tech support and it just happened to be a random electronics shop! That kind of annoyed me.
But i have to say i think i have just made a mistake on eBay today! I was watching a few amps and ended up bidding on a marantz one because it was pretty cheap: Marantz PM4200 all in £48. I'm starting to think i shouldn't have done this as when i checked online for instance under specs it says:
4200 = Power Output (8/4 Ohm RMS) 30 / 40 Watts
whereas my 7200= Power Output (8/4 Ohm RMS) 95/155 Watts (Class A: 25 Watts)
I only seen this bit after so i'm thinking it was a big mistake and that the 4200 could be noticeably inferior. I never have it up full blast but i just have a feeling this amp won't have the same sound quality.
I am thinking maybe i should just try and resell it on ebay and try and get my money back and get the 7200 fixed...
Wish i had of been outbid!
Anyway thanks for the help J Garcia & TLS Guy
