Couple questions about Yamaha RX-A3060
Hasan Alnajdi
Hasan Alnajdi
I hope I am not being annoying but could you guys have a detailed read on speakers and how to choose them? As well as subwoofers.
Lots of articles to read in general here http://www.audioholics.com/home-theater-setup
I think if you have no idea what speakers to choose you simply need to go audition as many as you can to get an idea of where your tastes lie; measurements can help. Subs are harder to audition as they're very room and setup dependent (and few showrooms have much choice in subs let alone properly setup IMO), I would chose mostly on specs. You might want to familiarize yourself with specs somewhat, this article might be a good start.
Budget range can determine choice to an extent also....
Hasan Alnajdi
Hasan Alnajdi
Dependin on the article from psb my speakers are 8 ohms and have a 90 efficiency (which I believe is the same as sensitivity). That is good in their ratings
The other speaker sure has more but beside loudness does clarity is effected by the other specs?
Not the same, efficiency is related to sensitivity but the better term when quoting the 90dB spec is sensitivity. 90dB and above are easier loads for an amp, which is a good thing.
Clarity is a subjective thing, what may be clarity to one may be brightness or even harshness to another, not everyone uses subjective terms uniformly....
Hasan Alnajdi
Hasan Alnajdi
I am confused my friend.. from my online search efficiency is measured as a percentage when sensitivity is measured in db.. now why would polk site refer to efficiency by db? Is it a typo or they mean some other kind of efficiency i didt get to notice?
https://www.polkhome.com.au/collections/floorstanding/products/tsx-330t-floorstanding-speakers
Look for specs☝
Hasan Alnajdi
Hasan Alnajdi
With powered subwoofers and other self-powered speakers, the power rating, whether FTC approved or WLS (When Lightening Strikes), doesn't really tell you much. Why? Because loudspeaker efficiency is by far the most important factor in determining how loud a system will play. Efficiency (a.k.a. sensitivity) is usually given as the amount of sound produced by 1 watt at a distance of 1 metre. A medium efficiency speaker rating would be around 87 dB from 1 watt at 1 metre. A highly efficient speaker might be 90 dB. Each 3dB increase in efficiency doubles the sound output for a given power input. So a 100-watt, 90 dB self-powered speaker and a 200-watt 87 dB unit would produce exactly the same sound output.
☝This is a qoute from polk audio site
Hasan Alnajdi
Hasan Alnajdi
Can you believe i found only one lousy 140 watts two channel power amp in the entire country? Its completely ridiculous.. but i dont know if i should even consider it
Kind of a waste to use an integrated amp where you just need a power amp. Do you have music stores there that stock pro-style amps like Crown, Behringer, QSC, Crest, etc?
Hasan Alnajdi
Hasan Alnajdi
I never even heard about those brands not mention a store that sell them.. i only found two stores selling avrs and both have idiots of employees... with my little knowledge i understand more about devices than they do.. guess i need a trip to dubai
The pro amps are more used by musicians, studios, clubs and DJs (we have chains of such stores to supply this market here, like Guitar Center, Musician's Friend, Sweetwater etc) but have been used by home theater enthusiasts as well. Some really good amp values can be had; I have several Crown XLS amps myself, have used them both for powering various speakers with an avr or pre-amp as well as use them with my DIY subs. Behringer has a very good value amp in the A500 for example if you could get one (and can live with the aesthetics, it's more intended for rack installation in an equipment closet rather than on display in a living room).
OTOH maybe its time for a trip to Dubai :)
Its the same thing i read... The efficiency of a system is defined as the ratio between the useful delivered power output divided by the input power, denoted by the Greek letter small eta (η).
You're probably right, marketing ppl
The AH site's definition is correct. It is quite often that people mix the two terms up but as long as they use the term dB/1W/1m or dB/2.83V/1m, you know it is sensitivity and not efficiency. Efficiency is typically expressed in % or in decimal number. For loudspeakers, expect efficiency to be very low, like less than 1%.
The site linked below has some good reads, including the efficiency vs sensitivity topics, and even a conversion formula/table:
http://www.sengpielaudio.com/calculator-efficiency.htm
Hasan Alnajdi
Hasan Alnajdi
Thanks you my friend.. its been helpful a lot
Yes, that's a good amp and even has rca connections and dual settings for sensitivity, fairly consumer friendly. Here on Amazon right now that one is $185 delivered, how much there?
ps Not sure about level of fan noise on that, so be aware.
Hasan Alnajdi
Hasan Alnajdi
here it's 85 K.D. after discount which is almost $280.. good thing you told me I will ask the seller about it
