Rick - the inside of the room is rocked. I have access behind every wall - the ceiling won't be rocked until after the electric is in. Then we will insulate all four walls and ceiling - add a second layer of rock on the four walls (with something in-between) and finish the ceiling.
Then GIK! I emailed them Tuesday with the room measurements (see below) - Bryan emailed yesterday with some additional questions - and again today. Since this room is a blank canvas - this is really helpful. Here is some of what he said:
The riser can be used but I would not do a Helmolz. That’s very narrow and tuned. I would like to use it more broadly by having the joists running front to back, insulated, and holes cut in the front as large as you can get them and still maintain the strength.
Seating position, try to stay out of the 40-60% range of the room length. Normally I’d do the first row at 62% of the room length from the front wall but that will push the back row likely too close to the doors to have a decent walkway. Might have to go 38% from the front wall for the front row and 33% of the room length from the rear wall to the back row. 120” diagonal at 9’ away (front row) is big but not out of spec.
So the equipment will have a 62” wide opening? Is it just in another room and this is a door or is it a built in? How tall? It’s smack in the middle of the reflection zone.
