Corner Bass Blockers- High or Low?
Kvn_Walker
Kvn_Walker
I ordered a set of 4 corner/wedge bass blockers (48" height) for my eventual room in House 2.0. Do I need to cover the entire corner, floor to ceiling (i.e. buy another set)? Ceiling is 8 feet.
Or will the 4' pieces be adequate?
And if I'm fine with the one set, is the optimal placement low to the floor, flush with the ceiling, or right smack in the middle?
I won't have my gear in this room until late August/early September... just moving along and planning and buying as I can find deals or get funds.
Mikado463
Mikado463
Kevin, they are are know as 'traps', as for ideal placement, floor to ceiling
Kvn_Walker
Kvn_Walker
Ack... you mean I can't glue these to the wall???
:p Eh, stupid typo. Forever preserved by the internet now. But thanks for the answer! I'll get another set of traps soon as I'm able.
Mikado463
Mikado463
you know, it's a fairly simple DIY project if you feel up to it !
ryanosaur
ryanosaur
I wouldn't even spend the money until you are set up in the room and able to run sweeps in there.
