Swerd
Building a cabinet so the drivers are time aligned is more difficult, as you can see in those plans. In theory it seems to be a good idea, but it is unclear whether people can hear any difference between speakers that are time aligned and those that aren't. So in the absence of any clear evidence for or against it, the deciding factor may be how hard it is to build the cabinet.So angling the front vs. the back would be the way to go to time align the drivers? How critical is that, I'm thinking not very since 95% of speakers are built on a vertical plane.
Remember that time aligned drivers are also phase aligned, if they have crossovers that generate 1st order acoustic roll off curves for the drivers. It is much easier to build speakers that are phase aligned, but not time aligned. A standard rectangular design will work with 4th order Linkwitz-Riley crossovers. The drivers will be in phase with each other, but 360° out of time with each other. To my ears, these are fine.
Another advantage for cabinets without 90° corners is that non-parallel cabinet sides minimize standing waves inside the cabinet due to internal reflections.
