Cain Highwind said:
I just checked the back of my satellite reciever and there is no Optical input/output. And I'm kind of confused on what you're suggesting.
Oops! A slight error on my part. I've taken another look at things...
Normally you would expect to connect a CD player (for example) up to a receivers CD jacks. You'd do this because you'd expect to hear
CDs when you select the
CD input. But by using the
DTV optical jack for the
PS2, my thinking was that you'd prevent yourself from using the
DTV jacks for
DTV (i.e. Cable).
In practice, I believe there
is a way around this, though it is somewhat convoluted: If you use the DTV optical digital and component jacks for the PS2, and the DTV audio and video composite jacks for Cable, you can select DTV and get both Cable
and the PS2, but you will probably need to ensure that whichever one you are not using is switched off, since the receiver will more than likely automatically switch to the best input if there's more than one for the same input (i.e. it'll try to use a digital source if it detects both an analogue and digital source for the same input)
Bet you're glad you asked!
Regards
