Connecting the Definitive Technologies Studio Monitor 65
dvcdank
This is my first post in the forum.
I just recently purchased the SM 65s. I noticed that they have the biamp wiring option. I will not be using that method. Should I just be connecting this up to the top pair of red blacks in that case?
Also, what should I set these speakers to since they have the sub built into them? I have them set to large currently. Is that ok? I think my Def Tech Center cs8060 channel also has a sub.
Would that be connected another way since it has the sub input?
Thanks all.
Hetfield
I have SM 65 LCR myself, great speakers, great choice. If not biamping or bi-wiring you can connect speaker wire to either top or bottom. Keep the metal connector place. The SM 65 doesn't have a built in sub, powered sub. They have a passive radiator. If using a sub, set to small, if not using a sub, set them to large.
Sent from my Pixel using Tapatalk
dvcdank
I have the Deftech Super Cube 2 II connected to my receiver. Should I set them to small ?
Thanks
That's a matter of debate as to whether the DT SCII is actually a sub :) I'd set your speakers to small if using it, tho.
Hetfield
Thanks
Yes, then set speakers to small. I crossover at 60Hz. The SM65s put out a good amount of bass.
dvcdank
Ok yeah, my options for crossover is 50 or 80. I haven't been able to settle on one. Mostly 80 is what I run at. Thanks for your help everyone.
Hetfield
Yeah with those options 80 is most likely best.
Why only 50 or 80? What avr do you have?
