Connecting PC and AV Reciever HELP PLEASE!!!!!!!!!
bluekn8286
Hey there everyone, I have a slight problem. I attempted to use a converter (a simple connector that splits a headphone jack connection into an RCA connection) in order to connect my sound card (on my PC) to my AV Receiver (Onkyo TX-SR805). However, when I attempted that, I noticed a pretty large buzzing noise along with the music I played from my computer. As a result, I decided un-hook all video connections (I had comcast connected to my reciever via a component video cabled and up-converted via an HDMI cable to my TV) and the buzzing noise was GONE!!!!!!
I think there is some interference from the video devices I am using that is causing this buzzing, but I have no clue. Any suggestions??????
bandphan
bandphan
headphone out and line out operate at different mv/v. Generaly if you only have 1 output on your laptop/comp you have to tell the sound card what to output. if you cant and you have to use the headpone out, id say there could be a ground issue. I wouldnt split that signal when using 1/2 for a line level signal.
adk highlander
adk highlander
Sith Lord
Sounds very much like the groundloop problem I had with my setup.
First are the plugged into the same outlet? If you can try and do this and see if it goes away.
I purchased an isolator off ebay for under 15 bucks. It worked great and the hum is gone. Impact Acoustics offers a much higher quality one for about 60.
This is a common issue for what I have read after the issue I had with mine. I have about 30ft between my computer and the gear.
Haoleb
Haoleb
Radioshack also sells a ground loop isolator for about 20 bucks. I use it between my computer and stereo and it works great. I did not notice any significant loss of signal quality either however I wouldnt use it on any of my higher quality sources.
http://www.radioshack.com/product/index.jsp?productId=2062214&cp=&sr=1&origkw=ground+loop&kw=ground+loop&parentPage=search
In response to what Bandphan said about splitting your signal, Your not actually splitting it your just changing the connection type so no worries there.
It's a ground loop for certain. An isolator transformer on you cable connection to your rig will cure it.
