M Madvej Audiophyte Oct 2, 2021 2 0 1 38 Oct 2, 2021 #1 Hello amazing Audiogon community, I checked on the forum but could not find a precise answer. If it has already been covered, sorry for the trouble in advance. My soundbar: LG Sound Bar SL4 My TV: Toshiba 40l3650 40" led tv Plugs on my TV are attached, they are like this: My soundbar only works with an optical audio cable. My TV has no "Optical Out". One more thing, I saw that maybe I could get a cable "Optical In" to "HDMI". However, it will not be suitable as all HDMI plugs are already used on my TV (the 2 of them). How can I connect them and keep a "good" sound? I have found an adapter for "Optical in" to "Coaxial out". Is that a good solution,? I have attached a picture: Thank you so much!
NINaudio Audioholic Samurai Jun 26, 2017 2,898 0 63 48 West Chicago, Illinois Oct 2, 2021 #2 You would need the opposite of what you posted, a coaxial in to optical out converter.
M Madvej Audiophyte Oct 2, 2021 2 0 1 38 Oct 2, 2021 #3 Okay awesome, the opposite then. Thank you! Reactions: NINaudio
