Connecting CD Player to amp question
KenM10759
KenM10759
Thanks. I knew about the Pro-Ject mat options. They also offer a leather mat, I've just never heard anything about using one. I'll keep my eyes open for something nice.
slipperybidness
slipperybidness
Yeah, in my opinion the stock mat from Pro-Ject on the Debut was not even serviceable. I had no option other than replacing it with something at least serviceable.
Carl08
Carl08
I'm not happy to hear about the mat. I bought a cork one anyway so it'll be replaced.
Do the Project tables adjust for arm height for different cartridges or mats?
KenM10759
KenM10759
I checked the manual for my RPM1 and the platter has no height adjustment, though there is a little adjustment in the tonearm mount for raising or lowering it. I don't know how much but it's probably less than 3mm either way.
I was curious, thanks. I looked at the Debut Carbon manual and didn't see it, but as it was in German.....mine has a range of settings gauged 0-6 for a range of cartridge heights of 15-21mm.
I wouldn't expect a platter height adjustment, though.
Carl08
Carl08
So, I'm A-B comparing the Onkyo C-7030 CD player connected via RCA and Coax. The RCA connection is definitely louder but I can't say it's clearer.
That's why you need to level match to do a proper comparison....
Carl08
Carl08
I received my Pro-Ject Debut Carbon DC yesterday and hooked it up. Levels are not far off from my other components now. Sounds excellent! This 2-channel setup makes coming to work much more enjoyable. Thanks
You have a good, compact amplifier. It's limitations are that it's got room on the back for just a couple of inputs and you have more. The weakest point of your devices is that AT-LP60 turntable. I would try to upgrade that. I know because I owned one and even the slight bump to the one I have now was a HUGE jump in sound quality.
Your current connections are fine, and the DAC in the Onkyo is a pretty good one. Would you notice any difference between that and the one in the 3020? I doubt it...I think they're essentially the same other than the one in the 3020 is probably a Burr-Brown.
KenM10759
KenM10759
Noticeably better than the LP60, eh?
Congratulations!
That was your issue, different levels compared to other components?
Carl08
Carl08
That wasn't the issue. It's a bonus though. This is just an all around better turntable
KenM10759
KenM10759
What do you notice most improved about it? I know from my upgrade from the same Audioquest AT-LP60 what I got, I'm curious what your take on it might be.
