Connect Yamaha RX-V365 to PS3
miguel 1966
I am trying to conect a RX-V365 to PS3. I am using the HDMI for video and optical cable for audio. The video works fine, but i can't get the audio (only via TV. I have a HDMI from the RX-V365 to the TV)
I have read that this is the way to do it, but I may be missing any configuration detail (or the equipment is just not working)
Thanks!
bandphan
bandphan
Thanks!
I may be mistaken but with the PS3 you can only get 1 digital output to work at a time. Whats your setup involve and can you run everything thru the yama? Does the 365 process audio via hdmi?
EDIT: if its all running thru the yamaha with hdmi, you do not need optical.
miguel 1966
Sorry I don't understand your question (I am a litle basic on this topics...)
I have PS3 connected to yamaha with both HDMI and optical. Then yamaha to tv with HDMI.
I was told and read that this is the way to do it but is not working.
Thanks for the help
miguel 1966
The 365 does not process audio via hdmi
bandphan
bandphan
what is you display? you may need to feed the audio back from the display to the yamaha. What speaker setup are you using? edit.. also if Im wrong about the processing of digital outs on the PS3 did you assign the optical input correctly ?
miguel 1966
The display is an old sony bravia (only one HDMI entry). I installed 5+1 spekers
miguel 1966
I don't know if I have assigened the optical input correctly. I basically tried all alternatives on the PS3 audio configurations but could not get it to work.
Thanks!
bandphan
bandphan
Thanks!
most avrs require you to assign the inputs within the setup menu
