Up until 2005, I had listened to audio via a CD player or Sony MiniDisc, or from the feed from the TV, or from the tuner that was in the pre-amp, all powered by an amp that fed tower speakers; video was via VHS, LOL. Then in 2005 I got flooded by a major hurricane that year and have been living in a very mobile way ever since, completely using my computer and its audio output jack to power either a pair of powered speakers - either Paradigm Active/20, or when I'm very mobile, a pair of conic-frustrum shaped Altec Lansing ones (both of which seem to be the best bang for the size/mass). Along the way I've picked up a pair of Montana Audio EPS (I was blown away by the clarity & bass extension for something that only cost $3K used; currently in storage), and when I finally get in a situation, I would like to start enjoying these in the way I used to prior to 2005 when I was less mobile.
Now since that time, I have completely changed over to having all audio & video stored on a computer hard drive, and pretty much just stream any radio station (that I would want to listen to) through my computer, so I have absolutely no use for a CD player or tuner. I can envision watching TV from either a digital antenna, or perhaps cable, but all other video will all be from the computer, including streaming as for radio stations. I also have an XBox that has 3 video & 2 audio RCA cables. As for the "computer", I could see wanting to get the audio or video from my main computer, or some type of pad computer that would be completely dedicated to the A/V. I could live with some deterioration of A/V quality from the main computer as it would be used when I actually want to get deeply into playing something, but I would want the A/V from the other dedicated computer quality to be excellent. For this system I have in mind, I am not interested in anymore than the 2 speaker channels. (I could see another system in which I would want the fancy multi-speaker systems, but I wouldn't be wanting to set that up until I will have set this current system up.) It can be presumed that any video is in the standard MKV, MOV, AVI, MP4 format, and any audio is WAV, FLAC, MP3 (constant or variable), although if it makes any difference, I plan to have everything on the dedicated computer as FLAC.
I have heard of A/V components termed something like "digital media component" that basically is a computer but with a very high quality sound & video card, but with a limited interface (I'm thinking something as limited as an iPad), but I think that I would like a much more general interface like I could get on a regular computer. I'm wondering if it is possible to get a general computer system that lets me run my own Windows apps like VideoLan that is specially designed to produce a very high quality audio or video feed that would be input to an audio pre-/integrated amp or TV; this type of computer would be the dedicated system for the A/V. Or perhaps regular computers these days are so good that the quality of the audio output is as good as anything so simply running a cable from that would suffice?
As for the feed from my other (main) computer, as this would be a notebook that be far away, I would prefer some type of wireless connectivity, and would not be so stringent on the quality (since the dedicated system would be used for those situations when quality is paramount). Is this something "Bluetooth" or other systems could handle?
So I guess my question is what will I actually need in terms of equipment. With everything now digital, I am not sure if what I need is a dedicated computer that puts out a digital signal that goes into the pre-/integrated amp and that gets DAC there, and then onto the amp, or if even now there are amps that directly take a digital signal, for the best quality. I know that I don't want to have a too-cluttered pre-/integrated amp setup and so don't want anything dedicated specifically for a CD, phono or tuner.
And if it matters, I am interested in an amp that does not put out too much heat; my experience with my old Adcom amp was that during the summer, I didn't care too much for the heating plate that it was. I understand that Class C or D amps have a much lower heat output, but that the quality has not been as great (although perhaps that has finally changed?) And I don't care for tubes and the artificial "warmth" they provide.
Thanks, and I welcome all suggestions!
