The Trek
2. Redesign enclosures for a more practical size, remembering volume can be reduced by several methods but you cannot easily make the box bigger.
5. Start modeling and repeat step 1 in practice.
6. Once your box is modeled, design your crossover. Store bought pre-made crossovers are useless. Don't skimp on this step, deign a good crossover and pay the cost. This is where you get the biggest bang for the buck. I would budget $100 - $200 just for the crossovers.
7. Peer review. Let others see what you are proposing to do and listen to the experienced people here. Heed their advice.
8. Go back and amend your design based on the peer review.
9. Build your boxes.
10. Build your crossovers.
11. Test and adjust you system and listening environment.
12. Beer-Thirty!!!
Halving box size
My thought is to cut the right hand box strait down the center; these cuts would then be the mounting faces for speakers.
If you visualize this the top and rear wall will have a slope, a side wall is missing; now turn the box over making the missing wall the base instead. Now the rear wall is sloped a little horizontally and one wall is narrowing in towards the back.
____________
I have a few types/variations of these concrete boxes, concrete pavers for the box floors and tiles to experiment with latter down the track.
Have not got enough in the way of cutting blade for this job, I will need to go to town in the next week so no pics for a while. The next step I can take is some basic maths on the volumes and speaker types.
I am starting from scratch when it comes to speaker types for enclosure volumes, which ever direction you start from.
##### ADDED
The speakers I owned previously, 20 years ago were digital acoustics strait out the shop, 2 main drivers one above the other plus mid and tweeter in enclosures 4 foot high, I remade the cabinets with heavier wood and the sound was very good but it was 20 years ago so I need to look around the net and see what people are using now.
When you consider that rear speaker information is 190 degrees that of front the speaker type, cloth angle vs. enclosure shape are considerable factors.
Going back to my prehistoric speakers, the sound was very good and I ended up porting them, no design in mind I just got a few lengths of pvc pipe and played around to find what I liked. I then, 20years ago heard a set of flat speakers (honey comb or something), first I had ever seen and such a speaker.
Anyway I bought a set and put them in small boxes that complemented my stereo.
This time I will put a little more science into it, but not too much.
Let us know your thoughts step 2-ish, one step at a time.
Cheers
http://picasaweb.google.com/garylooney/NewFolder?feat=directlink
