Another question – if you please.
Equipment:
Denon AVR 3805 Receiver
Denon DVM 1815 DVD
Sapphire MKII Towers (Axiom M60ti Towers on order)
Sapphire Center Channel
Comcast DCT6400 Dual Tuner DVR
Have the optical out from the Comcast box connected to the optical (2) connector on the Denon 3805 for audio. Still have the analog audio out to the TV and both can work at the same time.
Have the DVI out from the Comcast box connected to the Sony KV-34XBR910 DVI for video.
Denon 3805 is set up for fronts and center speakers only. I have adjusted the cable box’s volume to four points from the loudest setting. The box’s volume line displays “stereo” at this setting. One point less or more and stereo doesn’t display.
In general the sound sucks from TV. (CDs, DVDs sound great.) If the channel is broadcasting in Dolby 5.1 and I have the 3805 in “TV 5 channel stereo” it sounds ok, otherwise (and with any other non Dolby 5.1 channel) the sound has a very low volume output and just doesn’t sound right.
Question: Is it a bad box. Did I setup something wrong? What am I missing?
Thanks
