Are you sure? I thought you need a thicker gauge (at least 18 AWG) for those low frequencies. According to River Cables "to ensure low capacitance and low resistance, while delivering super signal power from your amplifier to your active subwoofer" they use OFC 18 gauge cable plus it has to be densely shielded in order to reject hum and buzz (due to EMI & RFI signals).
The supplied REL phono cable is very thin, it's actually the same one pictured below:
Compare it to the thickness sold by Impact Acoustics which is quite a difference:
Incidentally, I was also demoing a Martin Logan Dynamo sub. When I used the same cable I could hear a hum whenever I turn off my receiver. However, it disappears when I turn the receiver back on.
