Anyone looking for a nice Bluetooth speaker that will blend with the wife's decor, this product might interest you. With this in mind, Clear View Audio has designed their new Clio Bluetooth speaker which is almost invisible and you can put it anywhere in the house or office. This is unit was announced at the 2014 CES (Consumer Electronics Show) in Las Vegas and is their first audio system powered by Edge Motion™ technology.
In charge of delivering sound, the Clio features an optically clear acrylic glass stereo transducer, proprietary left and right channel piezo-electric actuators and a proprietary down-firing 2" woofer. I can't tell you about its sound and I don't expect it to be an audiophile's dream, but I confess that this product looks interesting. Check out the attached pictures and let me know what you think.
SOME FEATURES:
- Sources: Wireless Bluetooth Streaming or Direct 3.5 mm (mini-jack) Input.
- Decor friendly.
- Can be paired with up to 8 Bluetooth-enabled devices.
- Wireless Range: 30 feet (greater under certain conditions).
- Bluetooth® v2.1 compliant.
- Compatible with Bluetooth® 4.0 devices.
- Supports Enhanced Data Rate (EDR).
- Profiles Supported: Advanced Audio Distribution Profile (A2DP).
- Compatible with most iOS and Android devices (Smartphones, tablets, PCs and other devices that support Bluetooth® wireless audio profile [Advanced Audio Distribution Profile (A2DP)] or 3.5 mm audio output)
- Receives Audio Streams from Bluetooth 2.1 and 4.0 devices
***Tri-color LED and Status:
Blue (Bluetooth: Solid = Selected | Flashing = Pairing)
Red (Solid = 3.5 mm Input Selected)
White (Standby)
SOME SPECIFICATIONS:
- Height: 9-1/4"
- Width: 12-5/8"
- Depth: 3-3/4"
- 3.5mm Stereo Input.
- DC power input.
- Input: 100-240V 50-60 Hz 0.75A.
- Output: 24V 1000mA 24w.
- Clear Transducer Thickness: 0.04 inches.
- Weight: 1 lb. 15 oz. / 0.88 kg (Speaker only, no cables).
- Shipping Weight: 4 lbs. 2 oz. (including power cable, adapter, manual and 3.5mm cable).
- Available in black, silver and bronze.
- Limited Warranty - 1 Year / 60-Day Money Back Guarantee.
WHAT'S INCLUDED:
- ClearView™ Audio Clio™ Speaker System.
- A/C Adapter
- Power Cable.
- 3.5mm Audio Cable.
- Microfiber Cleaning Cloth.
- Quick Start Guide.
- User Manual.
Price: $349.00
Click on the following thumbnails to zoom in.
