Clean closet install
W
wchildress
I'm looking for a nice distribution panel. I have a 7.2 system with 2 zones. I want to wire everything up in-wall in case I change config. I'm looking for a 14" box panel similar to this wall plate by Vanco http://www.youdoitelectronics.com/id870.htm but I want a box. I've seen one from Elan but only at a installer's store. Any links would be appreciated.
Thx
BMXTRIX
BMXTRIX
You want a structured wiring enclosure?
If so, go to Parts Express and search for 'structured enclosure' and you will get a bunch of different types of boxes. On wall, in wall, etc.
I personally am terminating my distributed system directly to my wall, not a case, and then everything jumpers from my rack, to my wall, and out through my home. It works well and leaves me good access. The problem with a box, is once you have the wires run into it, then it may be tough to get those wires out cleanly if a change needs to take place.
That would probably be my only concern.
