eirepaul said:
By the way, does it have to be so complicated to dial in a subwoofer? Aren't some of you guys taking it a bit to the extreme. Perhaps I'm missing something, but I simply followed the guidance in the SVS manual and the sub sounds just great. Maybe it's an easy sub to integrate.
Everyone else has pretty much covered it. But let me just say that for years I just dialed in my subs using in the basic setup, ie: level, phase, crossover, etc. And things seemed fine. But the more I got into music in particular, the more I found that the bass either sounded a little "bloated" with some tracks, and on others a little "thin". I also noticed this on heavy action flicks. That's when I started to educate myself (mostly through the "net") about how heavily the room dictates how good or bad bass sounds in relation to FR. So I bought the three most valuable tools to see what was happening at all bass frequencies at the listening positions. A RS SPL meter, Test CD with sweep tones, and to adjust a BFD to help correct for room peaks (and even nulls to a much smaller extent by reducing other freq. around the null). Later on I also found the value of bass traps to help even out bass response.
In any case, one of the most valuable things anyone in this hobby can do is go out and buy a SPL meter and a test CD, and see what FR (frequency response) you
really have at your listening positions. Then if you have patience and like to "tweak" buy a inexpensive parametric EQ like the BFD and you will find the bass even more enjoyable to listen to then it already is. Or if you want something that is quite a bit easier to deal with, buy a Velodyne SMS-1 for more $.
Sure setting up a sub in the basic sense is pretty easy. If you want great bass, you have to work for it a little. Some
very select few have very good rooms as far as having a relatively flat FR to begin with. Most do not. To me it is not "extreme" to get the best sounding bass in any given room. Subs don't really dictate how good your bass will sound at the listening position, as far as nulls and peaks go, your room does.
