Hi,
I'm new, hopefully posting right, so be gentle
I have reference type audio gear (2 channel) and am either going to add a seperate surround system or try to integrate the two ... will try both, and go with what works.
The recievers I'm looking at thus far:
Denon 3805 (or I can get a 3803 for $400 less)
I'm also interested in:
Marantz
Arcam
others???
I want something that sounds 'musical' and that has some direct mode for 2 channel music that's decent ... again music first ... and the ability to integrate some entry high end amp(s) and more reference speaker (front L/R) into a surround set up that's geared towards:
1) sounding very good with music (including DVD-A)
2) integrating a primary front pair (probably bi amped) with a center and surrounds and sub to do double duty as HTheater.
Value is also key, it has to be good, and should be reasonable ($1000-$2,000 range ... not $10K and up range).
Thanks
