Choosing a speaker size setting help
Joe
Joe
Currently I have 2 Definitive Technology BP6B front speakers, C/L/R 2002 center and 2 Klipsch RW-10d subwoofers connected to my Denon AVR-1909. Would I want to set my fronts and center speaker size to "small" on my receiver?
MDS
The 'small' setting means that the receiver will redirect bass frequencies below the crossover setting to the subwoofer(s) and 9 times out of 10 is the setting you want to use when you have a sub.
Some of those DefTech speakers have built-in subwoofers and if yours do then the setup is a bit more tricky because you might have to set them to 'Large' so they see the full frequency range and can send the bass to its internal subwoofers. You can still set any other speakers that don't have built-in subwoofers to 'small' so their bass gets routed to the Klipsch subwoofers.
