RyanEarlDunn
HTIB around $150 Canadian
looks like an awesome deal but then again I don't know anything can you check these specs and tell me if it's the steal I think it is? Thanks
Specifications: Amplifier Section
R.M.S
9W x 5 , Bass 12W
P.M.P.O
1500W
THD
10%
S/N Ratio
45dB
Frequency Response
20 Hz ~ 20 KHz
Input Sensitivity
500 mV+/- 50 mV
Input Impedance
>10 K Ohm
Speakers Section
Woofer
Satellite
Driver Unit
5 1/4" Woofer
2" Full Range
Dimension
320 x 180 x 243 mm
120 x 90 x 208 mm
Impedance
8 Ohm
4 Ohm
Max Output
30W
10W
Magnetically Shielded
Yes
Yes
Operator Section
Power(AC/DC)
AC
Power LED Indicated
Yes
Earphone Jack
No
Power ON / OFF Switch
Yes
Volume Control
Yes
RyanEarlDunn
The description says they're for everything (not just for comps) and right now I'm sitting on 5 watt cube speaker 15 watt sub LMAO yea yea I know don't even make fun. Is it worth the price though? What's 10%THD?
nibhaz
nibhaz
THD stands for Total Harmonic Distortion. In general, the rule of thumb is to remain below 1% THD at all cost.
10% THD ….well, I would consider those to be vary expensive paper weights, IMHO!
BMXTRIX
BMXTRIX
Those are not an upgrade - they are a waste of your money for something that is really not worth mentioning.
They are the steal they appear to be - but not the way you think they are.
That is - they will be happy to steal your money and give you a very cheap, not so great product.
Why not try something like this if you can swing it:
http://www.jr.com/JRProductPage.process?Product_Id=4007837&JRSource=google.datafeed.ONK+HTS770B-RB
or here:
http://www.ecost.com/ecost/shop/detail~dpno~474173~Action~Detail.asp
Read the specs on the HT-S770 system... Instead of 9 watts * 5 plus a 12 watt sub, this is 130 watts * 6 plus a 220 watt sub.
Instead of a 4" sub, it has a 10" sub.
Instead of 10% THD - try .08%
Instead of a total weight that's probably 10 pounds, this comes in a box that weighs about 70 pounds.
It is very serious and a great deal for the price. Far, FAR superior to what you are looking at right now.
Don't waste your money on some half baked upgrade when you can save it for a few more months and get something that will really blow away what you have now. You really won't be sorry you did.
nibhaz
nibhaz
BMXTRIX,
Thank you , for saying everthing I'm to lazy to say!
RyanEarlDunn
ya thanks for saying everything he was to lazy too LOL. Thanks for the help guys I know it's annoying to hold a newbs hand through everything and I appreciate it. I'm probably gunna end up with that system thanks for the recommendation.
CaliHwyPatrol
CaliHwyPatrol
Everyone has to start somewhere! ;)
I didn't click on those links but one of the url's had Onkyo HTS770 in it. That is going to be <b>a lot</b> more bang for your buck than those computer speakers!
~Chuck
