Cheap sound insulators?
Y
yepimonfire
im looking for something cheap to reduce the echo of my sound room. want to put my system in a concrete basment, and please dont recommend some 2000 dollars a slab acoustic material i dont have that kind of money nor am i willing to spend 4 times the cost of my sound system on acoustic stuff. im wondering if Styrofoam insulation will reduce the echo. any ideas?
Y
yepimonfire
any ideas on how to set them up without screws, im renting this house and am looking for the least amount of footprint to set them up
You can also just mount a rug or some other type of fabric on the wall. It won't be as effective as panels, but it will drop reflections quite a bit.
just-some-guy
just-some-guy
go to home depot/menards/etc. go in the insulation dept. look by the 4x8' sheets. there is a panel that "looks" to be made from compressed shreaded card board. one side has a black paint(?) on it, the other side is beige . it is soft enough that you could break a piece off real easy. it should be about $8-10 a sheet.
bang for buck. this stuff can't be beat.
