Eppie
Eppie
I tried to find an impedance curve for the Cerwin Vegas but came up empty. My concern is that the impedance may dip down to 2 ohms in the lower frequencies. The Pioneer may be ok at lower volumes but if the op is into rock and metal he's likely going to want to crank up the volume at some point and I wonder whether the Pioneer is up to the task. Will help to know what other gear he has and hopefully we'll get a more detailed list.
Philster65
The speakers are currently Paradigm rear bookshelf with a Paradigm centre and sub. then the Cerwin Vega. I also have a Harmon Kardon 1610s that i could hookup instead of the Pioneer. The speaker wiring is heavy gauge and are all cut to balance distance between speakers which are in a room that is 15' x 15'
Kingnoob
Kingnoob
Supposedly a great brand I’ve not had Paradigm yet , what pioneers are you using ? Are cerwin fronts ?? Get some pics of the set im lost …
