Centre Channel Options
Big Dub Sounds
Got a bit of a tough situation as I have the Polk RTI A3's as my fronts and would like to voice match with either the CSI A4 or A6. Problem is space is limited and I'll need to mount below the TV, are there any mounting options for centre channels of that size?
shadyJ
Speaker of the House
Staff member
Most center speaker mounts are little more than shelves. The ones that actually attach to your center speaker assume you are using a very small center, and so they do not have much weight capacity.
everettT
everettT
They make mounts for above the tv. Some can mount to the VESA mounts on the tv itself. What are your size limitations below the display
