I have small room (4metres X 5metres) I have recently purchased a 5.1 Tannoy FX speaker package. I have mounted a speaker in each top corner of the room. I have also mounted the centre channel (which is identical to the other 4 speakers) in the centre position about the TV but at the same height as the other speakers. I have the powered Tannoy sub on the floor (left hand side of the TV) I'm using a Yamaha RX-V650 AV, will this centre channel placement work ok. I plan on running wires through the roof/walls next week but I've been told the centre channel should be at eye level, but I like all the speakers where I have put them. This is not a big dollar setup so will it really make that much difference? The Yamaha has the new optimizer setup mic feature, surely that will make the necessary adjustments for me.
Justin
