center speaker placement question
L
lestat0521
I just purchased a new HDTV and dont really have a place to set my center speaker (my old tv had room and i had it set on top).
My question is:
-is it alright to have the center speaker lower then ear level angled up toward ear level? or do you have to have it ear level or higher to get good sound?
thanks.
W
wyllisx1
I have my Bigfoot below my tv & angled up. It works fine.
In the tutorial in the sticky on speaker placement it advises to use a laser pointer or something like that & make sure that when it is placed on top of the speaker the light points to your ear level. I didn't use a pointer but a flashlight & it worked out ok.
