Not sure I’m a beginner or an audiophyte, but I’m posting here because I found a similar question posted in this forum.
I usually stream video from a Roku Ultra 4800R, with surround sound processed by a Yamaha RX-A3050 A/V receiver. I’m normally happy with the surround sound the receiver delivers to my 5.0.0 speakers.
I noticed recently that when I play the current NBC series The Endgame from the Hulu app on my Roku, the center channel is silent, making dialog difficult to understand.
I suspect the problem is caused by NBC or Hulu, but I’m not sure I can rule out my own setup. Can someone tell me whether the following behavior eliminates my setup as the source of the problem?:
The receiver Information menu shows the Endgame source audio format as Dolby Digital+ 7.1 (3/4/0.1) -- i.e., 3 front channels, 4 surround channels, and 1 LFE channel. It shows output to 5.0.0 (which correctly corresponds to my 5.0.0 speaker setup). As noted above, I hear no center channel audio.
Other Hulu videos, including the ABC series Gray’s Anatomy, have the exact same source audio format and speaker outputs, and they have clearly audible center channels.
In this comparison, the only variable is the TV series being played. Am I correct to conclude there’s nothing I can do on my end to fix the problem? If it’s useful, I can post additional details about my Roku and receiver audio settings.
Out of curiosity, I tested Endgame playback using other apps and devices, with the following results:
Using the same Roku and receiver, but switching to the YouTube TV app: Receiver shows the same audio source/output formats as when I use Hulu. Center channel is not audible. This suggests the problem is not Hulu-specific and might be caused by NBC, Roku, or my setup.
Using the same receiver, but switching to the Hulu app on Apple TV 4K: Receiver shows source audio format as PCM 2.0 (2/0/---) and output as 5.0.0. Center channel audio sounds good.
Using the same receiver, but switching to an OTA HD TiVo, with signal coming from my local Los Angeles NBC station via a rooftop antenna: Receiver shows audio source format is Dolby Digital 5.1 (3/2/0.1) and output is 5.0.0. Center channel audio sounds good.
Thanks for any insight you can provide.
