Center Channel and Rear Speaker Selection
sgtpepper9
sgtpepper9
I have the Klipsch RF-63 floorstanders. The matching center channel recommended by klipsch is the rc-64. But I have found a good deal on the rc-62. Would it be a bad idea to pair the rc-62 with the rf-63? Also the same applies for the rears. The recommended pair is the rs-62s but I have found the rs-52s for a really good price. What do yall think?
Midcow2
Midcow2
Can you audition the RC-62 ?
The most important match is the fronts and center. If you can audition the RF-64 with RF-63 similar to yours and then compare with RC-62. if it sounds good to you go for it.
The rears are not near as importnat because they provide presence or enhancement surround sound and are not your main sound. Again if the RS-52s sound good go for it. Mathcin the rears is not near as imprtant as the ftont/center match.
good luck.
STRONGBADF1
STRONGBADF1
good luck.
Agreed.
The tweeters in your RF-64 and the RC-64 are 1.25". The RC-62 has a 1" tweeter. Make sure you go listen to be sure It's a difference you can live with or if you can tell that there is a difference.
SBF1
