Below you say you cannot rely on DBt, industry cold standard. How can he rely on this suggestion? It is based on nothing.
I'm not so sure how much you can rely on just using double-blind tests to compare things.
Why is that? You rely on DBT protocol for medicines? Other human testing?? and most everything in science?
Why not in audio?
Maybe the answer is not apetising?
For example, Dolby say that Dolby Digital has been shown to sound exactly like original studio masters. This was probably a double-blind test. In my experience however, DTS sounds quite different to Dolby Digital.
Oh, it may, especially when apple and an orange is compared. But, that is not the fault of the DBT protocol itself but what was compared and technically how.
I once read an article in the New Scientist on how scientists tend to produce results they want to produce. This is not to dismiss DBT's as useless, but to treat their results with a little caution.
No, DBt has no mind of its own and certainly not psychic to know what the tester wants.
However, in science, replication is everything. If others can replicate the results, what then? Another excuse?, or a valid result? Same applies to audio.
CD players do have different designs, some of which are better than others.
Maybe yes, maybe no. And, maybe the differences are not audible. The specs will show it.
It's difficult to know whether higher quality designs sound better or not.
Actually, it is very simple to find out and easy to know. One must want to know though. Many don't want to know as if there is no audible difference, why buy the expensive sugar???
Yes, real sugar has different prices in the store. Have you noticed? Do you buy the more expensive sugar?
Getting a good quality CD player won't do you any harm, especially if you listen to lots of CD's.
Well, not a physical one
Maybe to the pocket book?
Also a well-made, more expensive CD player, will last longer than a cheaper, less well-made one.
Maybe. Or, you can replace the cheaper one more for less overall
