I
indcrimdefense
demoed the new DVD 7 from cary audio this weekend. as a current owner of the DVD 6, was excited to see what the new model had to offer, & i was not disappointed. the video was the best i have seen from a DVD player. over the weekend had friends & family over, none of which are video or audiophiles. all liked the 480i picture out of the dvd 7 over 720p or 1080i out of my denon 2910. however once i hooked up the progressive output (had to find bnc adapters) it was an incredible picture, clearly superior to the dvd 6 picture quality. the audio portion sounded fantastic as well, but was not quite as big an improvement over the dvd 6 as the video. however i was the 1st to use the audio connections (dealer had only used digital) so unit was not broke in. dealer is going to hook it up & let it play continuously for awhile & then going back for another demo. this is not to say that the dvd 7 does not sound better than the dvd 6, it does - but it also has xlr connections & the ability to turn the internal volume control off, which the dvd 6 lacks. switching between the 7 & the 6 i used a spl meter to compensate for the xlr/rca difference in volume between the 2. using the rca on the dvd 7, i could not distinquish the sound from the dvd 6. unsure whether i will purchase it or not, unless the break in truly results in a significant increase in the sound quality over the dvd 6 (i doubt it but i try to keep an open mind). however if you don't own a dvd 6 & are looking for a 1080p dvd player which has exceptional redbook cd playback, take a look (& listen) to the new dvd 7.
I
indcrimdefense
after the dealer hooked up the dvd 7 at the shop for awhile using the audio connections, took home for a 2nd demo. sound quality now is clearly superior to dvd 6, particularly in treble & vocals. it was not easy to unhook it & take it back in to the shop. unfortunately, the deciding factor for me is that it does not play sacd, dvda & lacks multi channel audio in analog (obviously has using digital connection). while it is a substantially better player in audio & video than the dvd 6, going to continue to shop for a new univeral player. however if your looking for stunning picture quality all the way up to 1080p & a very good redbook cd player, & have no need for sacd/dvda, it may be worth a look.
jcPanny
jcPanny
DVD processing
Intersting feedback on the new DVD player. It sounds like your HDTV's processing is superior to that of the Denon. Also, from my experience, the audio quality is usually a function of the DSP processing and D/A conversion and not the digital output.
