I have a Carver PM 600 that buzzes at the speaker output. If I leave a speaker hooked up to it, it blows the speaker. Before the speaker goes into meltdown, the cone is pushed out toward the listener. Disconnecting the pre-amp circuit from the power circuit within the amp has no effect. The LED meters for both channels on the front panel of the amp are pegged, when I turn off the amp the meters cascade down to zero. The pre-amp section is functional and tests fine, but none of the sound makes it through the amp. The amp is bridgeable at the beginning of the power amp section. Bridging has no effect, the DC at the output is equal in both channels. The amp appears to be amplifying whatever is wrong in the beginning of the circuit. If I disconnect the lower voltage supply from the transformer that supplies the op-amps, it goes back to idle. It has a regulated on-demand power supply with 3 voltage outputs, 22, 46 and 73 volts. The 2 higher voltages are only stable when the lower is disconnected from the amp. The amp appears to be running at full volume with no input and the controls at zero or even disconnected all together. By disconnected, I mean removing the jumpers for adding extra modules between the pre an post sections of the amp. This removes the input section from the chain. I have replaced some suspect components, but it still buzzes. Any ideas?
