If you knew which set were in use at any given time, then the test was flawed.
Not really...believe me, I WANTED the Blue Jean cable to win so that I could sell off the cardas.
But every time the Cardas was Bigger sounding deeper Bass a Bigger "Sound Bubble"
Just more info coming through. The Blue Jean was a smaller leaner sound smoother on top then the Cardas where as the Cardas was not forgiving of bad sources but the connection to the Music was better then the Blue jean.
There is no measurement for sound stage with. or depth .
Just because you can't measure it does not mean you don't hear it.
trust your ears...its all that matters!
