Car sub - help me choose
myriad1973
I know this forum isn't geared toward car audio, but I've been on this forum off and on for a number of years and I trust your opinions.
I'm trying to decide between a Infinity Reference 1262w, Infinity Kappa 120.9w or a RE Audio SCX 12"? I've also seen some Boston Acoustics G3 subs showing up on Ebay lately too. I'm going with a sealed box around 1.5 cubic feet and about 350-400 watts rms.
I'm looking for best value for the money.
I'm on a tight budget this time, otherwise I would go with a JL Audio W3, like my old setup.
I already have Infinity Kappa components and coaxials in the doors and rear deck.
slipperybidness
slipperybidness
I am not familiar with the RE brand.
Of your choices, I would personally choose the Kappa.
I also used to have a pair of the 1262w in separate boxes in my car. I can tell you that the Infinity Reference line puts out some serious thump!
rojo
rojo
RE Audio makes some pretty impressive looking drivers. Unfortunately, IIRC, they aren't easy to model. Their published T/S parameters are hard to work with due to many common values not being provided. The Infinity drivers are much better documented. For a sealed box, I'd go with the Infinity Reference 1262W. The RE driver may offer more output per watt, but I don't know whether I'd trust the manufacturer's recommended box size and tuning frequency enough just to build it and see what happens. In any case, RE recommends a much smaller box than what you have planned, unless you change your mind and go ported.
myriad1973
Thanks for the input. One thing I like about this forum is I usually get a lot of intelligent responses instead of "get Boss subs" or something like that.
I wasn't too sure with the RE either, based on the lack of technical data. I had to e-mail them just to get the frequency response, which they said 20 - 200 Hz, which I'm not too sure about as well.
I have seen some Boston Acoustic G5's popping up on Ebay too, and most of the Boston subs (G2 and G3) have a Qts above 0.6. The G215-44 15" DVC is going for $70 new on Ebay. I'd jump on that, but I have a wife and kids, so I have to behave somewhat. lol
I've been leaning toward the Infinity subs, as they seem to offer the best performance for the money. The JBL GTO-1214D (Harman yet again) has similar specs and price to the Infinities.
After having a JL Audio W3 at one time and knowing its sound and capabilities, I'm a little hesitant the Harmans won't perform as well, being disappointed and stuck with it.
