Car Speaker Blown - Use Dummy Resistor?
heatsink101
heatsink101
Hey guys. I blew out one of my speakers listening to Nirvana. It now rattles and buzzes and sounds like terrible crossover distortion.
Since I'm totally broke, I'd like to just remove the speaker until I can afford a replacement.
My question is whether I should just leave the connection open, or if I should add a resistive load so the amplifier can continue as usual.
slipperybidness
slipperybidness
I would simply pull the fuse from the amp.
Otherwise, if you want the amp to keep driving other speakers, then I would disconnect the fried speaker, preferably disconnect it from the amp. If that isn't convenient, then I would disconnect from the speaker, clip off the bare wire end, and wrap it several times with electrical tape to keep it from shorting on anything.
A blown speaker DOES NOT sound like crossover distortion.
Disconnect the speaker and don't try to reach the same SPL.
heatsink101- how old is the speaker? Any chance that it's under warranty?
Also, who installed the system? If the amp's input level controls are cranked up, that's what really caused the problem. Setting these correctly means you should NEVER reach the level of distortion that may have killed your woofer. However, it's possible that the amp can output more power than the speaker can handle, so it would be best for the future longevity of the system that you make sure the system is dialed in so it's not overpowering the speakers.
slipperybidness
slipperybidness
So that's what those gain knobs are for on auto-amps :D Who knew? :D
