Car Audio -111W Rms, 50W Rms ...Same Price Tag ??
satish536
Its funny how this infinity amp is rated at 111W Rms per channel <So much power)
http://www.circuitcity.com/ssm/Infi...roductDetail.do
But in the same price range other amps are just about 50W to about 60W per channel( A MTX and Kicker Amp ) :-
http://www.circuitcity.com/ssm/MTX-...roductDetail.do
http://www.circuitcity.com/ssm/Kick...roductDetail.do
I think Infinity is a repuated brand !!They wouldnt be outrite givin false ratings rite ??? Or is it just one heck of a superb deal to get that kinda power for that cheap ?? Explain me the whole story, Im so confused !!
Any help, info will be appreciated
Also if i drive my pioneer 80W Rms rear speakers with this 111W Rms Infinity Amp , Will i blow them beacuse of the extra power ?????
TheHammer
In the car audio world there are lots of variables when rating amplifiers.
You seem to have a handle on RMS vs MAX, that's a good start.
Usually they are rated at 4ohms. Some manufacturers rate the Watts with different voltages supplied to the amplifiers.. 12V 13.8V 14V and 17V even. Sometimes they are rated at a certain frequency, and sometimes at a frequency range. Also rated at different distortion levels (THD).
You may find some amps with a crossover built in, and some without.
Some have 2 channels some 4 channels. Some are 'class A/B' some are 'class D'. Of course they are all built with similar components, but some surely have better quality parts and better quality control.
Hope that gave you a bit to think about.
The Hammer
