irishdroog said:
So, are you saying that the Playstation should be hooked straight to the TV and the TV should then be hooked straight to the home theater?
Couldn't I hook both the Playstation and TV to the home theater? Or would that cause a problem somewhere?
What happens if I can't find/get internal speakers to turn off? Is there another way around this problem?
P.S. Thanks for all your help already!!!
Irishdroog, it depends on how many inputs you have on your receiver.
Assuming you have more than one audio input on the receiver:
1. Connect the red and white audio cables from the playstation to an input on the receiver (lets call it audio1)
2. Connect the yellow video plug from the playstation to a video input on the TV (video1)
3. Connect the audio OUT on the TV to an input on the receiver (audio2) with red and white RCA cables.
To play playstation, turn the receiver onto audio1 and the tv to video1.
To watch TV, turn the receiver to audio2 and tv to normal video (hit tv/video until you get your cable picture back).
If you only have one audio/video input on the receiver:
1. Connect the red, white, AND yellow cables from the Playstation to the TV (video1).
2. Connect the audio OUT on the TV to the input on the receiver (audio1).
To watch tv, turn the receiver to audio1 and the tv to normal video.
Turning off the tv speakers shouldn't matter. You can just turn it all the way down. Some tv's have a "fixed/variable out" under audio options. Fixed out means you're controlling the volume on the receiver and only the receiver. Variable, you can control the volume with the tv remote.
Either way should work.
