Cans for $150 or under
zhimbo
zhimbo
Ahhh, I know what you mean now. Since you've had the same earphones, do you know of any aftermarket ear pieces that might fit better? The mediums are a touch too small, but the larger ones are too big.:(
I was able to get a decent fit. There's always a bit of luck, I guess. If I wore them while running or something like that, it may have been a problem but for walking/sitting during my commute they were great. I'll probably get around to getting a replacement pair in the next few months.
Headroom sells "Comply" brand replacement foam tips that will apparently fit the Klipsch S4:
(pdf link)
http://complyfoam.com/content/compatibility_t-100.pdf
