Can you get reasonable quality with mp3s?
  • Thread starter Thread starter samson
So from responces here and elsewhere it seems to be a toss up between an M-Audio soundcard and a USB extrernal soundcard device like the Edirol UA-1A. Basicly the same price (55 GBP), does anyone know what the relative sound quality would be like? The other factors are -
The convenience of the USB device, I could swap it between my desktop and my laptop, and use other peoples if they came round with music.
The proccessor demands of the USB device. I belive that the USB protocol makes significant demands on the CPU. I would offen be compiling or playing games with the computer at the same time as playing music. Would this cause problems?
Thanks for the help, I think I am getting there.
BTW, my mp3's are downloaded (legaly) so I cannot rip them again.
You have a good handle on the trade-offs between the two choices. Yes, USB is 'host based' and will use more CPU than an internal card. I would choose the internal card if it is for the desktop.
I don't play games, but I frequently play music (streamed from my other 'media hub' computer) while I work and the soundcard never uses more than 5% CPU. If by 'compiling' you mean compiling code at the same time, that will not be a problem - I do it every day.
