Can someone help me model a sub Please?
annunaki
annunaki
Moderator
TLS thanks so much for taking the time to model these for me you are truly a stand-up guy in my book especially taking time around the holidays. I do have a question though it appears from your graph that the 10w3 has a vent velocity of 20m/sec at F3 is that acceptable? Is there anything I can do to combat this?
A slightly larger vent that is also bit longer would do well.
The 10W3v3-4 models very well in a 3.0ft^3 enclosure tuned to 24hz.
Using a 23"H x 17"W x 24.5"D enclosure with a slot vent at 2"H x 15.5"W x 43.5"L would yield -3db points at 21.9hz and -3db at 85.75hz remaining ruler flat in between at 111db simulated anechoic!! Vent velocity remains just below 17m/s over the entire range.
This alignment does assume a low-pass x-over at 80hz 2nd order and a high-pass (Infrasonic filter) at 20hz 2nd order.
The volume would account for bracing (window braces of minimal displacement) and driver displacement.
Coheednme13
Coheednme13
that sounds pretty awesome should I build it sort of like the kappa design just with different measurments. I'm sorry I'm such a noob. LOL
Just about. Since this was for a bedroom I made a reasonably small footprint box, and so I was concerned about fitting a longer port in the box. If you build the 3 cu.ft. box and the longer port you will solve it.
Coheednme13
Coheednme13
it is for my soon to be dedicated HT but it is a small room so I don't want the sub to be huge but I think it will have to be so whatcha gonna do :p thanks for all the help
Do I need some rockwool or anything to line the enclosure
Yes, you will need to cover 50% of the interior surface with Mineral Wool, especially behind the driver. For smaller rooms like you describe the smaller box will work fine, and the vent velocity at the power you will use will be fine. The larger vent slows the air speed about 3 m/sec, for a vent velocity of 17 m/sec. I calculate the vent dimensions to be 2" X 13.25 X 43.5 for the 3 cu.ft box. You will need to add driver displacement and, bracing and amp volume to the 3 cu.ft.
Coheednme13
Coheednme13
So for future reference when you build an enclosure- let's say you want it to be 3cub. ft. I know you have to add driver displacement and bracing to the enclosure size but do you also have to add the displacement of the wood making up the port?
Yes you do.
annunaki
annunaki
Moderator
The air in the vent cannot be included. The design I offered counts for ALL displacement.
Coheednme13
Coheednme13
MDF suitable? Annunaki you have a single window brace? Does the design include displacement for adding some mineral wool or treatment?
annunaki
annunaki
Moderator
I have not used just a single window brace in any of my designs. I typically use a bracing system which is a series of window braces tying all 6 panels together with no more than 7" of any one surface unbraced.
You will have no issue using 25% coverage in mineral wool along with some good bracing techniques in my suggested design.
Coheednme13
Coheednme13
I was looking at your JL 13w1 build should I do a similar bracing technique? Will I need to add volume to your design or is the design assuming a bracing technique like the one you used?
annunaki
annunaki
Moderator
You would probably want to add another .10-.15ft^3 if you added that much. I would suggest similar bracing, though you could get by with a bit less.
Coheednme13
Coheednme13
now when measuring port length do I measure along the bottom and back of the port or do I measure the wood used to make the port? Trying to come up with a design. I wouldn't mind paying someone to come up wtih a cut list and design. I am glad that I'm learning though since you guys are helping. Let me know if you understand what I'm saying as far as the port goes.
The length is calculated along the center line, including bends.
Coheednme13
Coheednme13
So I have 2 different port options from you guys. So if TLS guy has the optimum port at 13.5 inches then what would be the difference in going with a port that is 15.5 inches annunaki suggests. Would the driver become sloppy?
I was calculating on a final internal volume, and having you add the displacing addition of braces and wood for ports etc. Apparently Annunaki allowed for this.
I have looked at this closely. I think you will end up with around 20% of your final volume being braces etc. So if you have, an actual volume of air of 2.7 cu.ft. in your box the system tunes pretty much optimally. Your final volume will probably end up between 3.1 and 3.5 cu.ft, depending on your bracing and amp.
If that is the case the box tunes optimally with a vent of 2" X 12.5 X 45.75"
This gives you an F3 of 21.9 Hz and a vent velocity peak of 17 m/sec.
So that is my final calculation for you.
Type: Standard one-way driver
Company: JL Audio Inc
No. of Drivers = 1
Fs = 32.97 Hz
Qms = 7.027
Vas = 32.17 liters
Cms = 0.19 mm/N
Mms = 122.4 g
Rms = 3.61 kg/s
Xmax = 14 mm
Xmech = 21 mm
P-Dia = 209.6 mm
Sd = 345 sq.cm
P-Vd = 0.483 liters
Qes = 0.533
Re = 1.7 ohms
Z = 2 ohms
BL = 8.995 Tm
Pe = 500 watts
Qts = 0.495
no = 0.209 %
1-W SPL = 85.37 dB
2.83-V SPL = 92.07 dB
Box Properties
Name:
Type: Vented Box
Shape: Prism, square (optimum)
Vb = 2.7 cu.ft
Fb = 22.94 Hz
QL = 6.68
F3 = 21.88 Hz
Fill = minimal
No. of Vents = 1
Vent shape = rectangle
Vent ends = one flush
Hv = 2 in
Wv = 12.5 in
Lv = 45.73 in
annunaki
annunaki
Moderator
No. of Drivers = 1
Fs = 32.97 Hz
Qms = 7.027
Vas = 32.17 liters
Cms = 0.19 mm/N
Mms = 122.4 g
Rms = 3.61 kg/s
Xmax = 14 mm
Xmech = 21 mm
P-Dia = 209.6 mm
Sd = 345 sq.cm
P-Vd = 0.483 liters
Qes = 0.533
Re = 1.7 ohms
Z = 2 ohms
BL = 8.995 Tm
Pe = 500 watts
Qts = 0.495
no = 0.209 %
1-W SPL = 85.37 dB
Box Properties
Name:
Type: Vented Box
Vb = 2.7 cu.ft
Fb = 22.94 Hz
QL = 6.68
F3 = 21.88 Hz
Fill = minimal
No. of Vents = 1
Hv = 2 in
Wv = 12.5 in
Lv = 45.73 in
Are you accounting for the volume displaced by the vent? All of the items I have ever encountered on vented enclosures states that the volume inside of the vent cannot be counted in the total volume, as would be the volume of the material used to construct the vent.
My design accounts for this and bracing. I always suggest a slot vent of a specified width as it is the same as the internal width as the enclosure, thus simplifying the construction process and adding additional structural integrity.
Coheednme13
Coheednme13
Are you accounting for the volume displaced by the vent? All of the items I have ever encountered on vented enclosures states that the volume inside of the vent cannot be counted in the total volume, as would be the volume of the material used to construct the vent..
I need to know this answer so that I can begin designing the enclosure
I plan on making the width of the enclosure to account for this because I feel you state the bennefits of simplifying construction and adding strength. I'm trying to take Annunaki's enclosure dimensions and TLS's vent recommendations and blend the two to end up with a net enclosure size of 2.7 cubic feet
Again to both of you guys you are both really great treasures to this forum for helping me so much. I can not tell you how much I appreciate your help.
Matt
