I expect that from an aesthetic perspective, you’ll like these better than the little halogens. Those things have the bulb right at the surface, and I find the glare they produce to be really irritating. The nice thing about regular recessed lights is that the bulb filament is placed up high in the can, so you get nice lighting with much less glare.
The link doesn’t say, but I’m guessing they take the small Par 20 bulbs? Cans for the large Par 40 would be even better. The 40s and 20s have the filament the same distance from the socket, but the larger Par 40 bulbs require taller cans. This means the bulb filament is considerably higher in the ceiling than with Par 20 bulbs, making for even softer, more pleasing lighting.
BTW, don’t go with those Par 40 fluorescent bulbs. Sure, they save energy, but they have the light element down low in the bulb, which means they glare about as bad as those little halogens. If you want fluorescent bulbs, you’d be just as well off to go with a surface-mounted fixture, which can be had cheaper than recessed cans.
Regards,
Wayne A. Pflughaupt
