Hi,
I'm a newbie here. Can I use a 4 ohm car amplifier to power up my home speakers? I'm thinking of using a Focal 2 channel amp to power my monitor audio rear speakers. Thanks
That is a very bad idea. The amp will output about 35 watts at most to your speakers and be voltage limited.
Car amps have oscillators in them so the 12 volts can be stepped up to give enough voltage to the power transistors to give more then a meager few watts of power.
So you are going to take your 120 volt AC at the plug turn it into 12 volts DC, and then have the car amp power supply up the voltage to 40 volts AC or so and then rectify it to DC. That is a mess and asking for trouble.
It is always a bad plan to use car audio devices for home audio.
