I might be wrong; but, I don't think you are going to get the desired result. What you will get is a very unbalanced stereo effect from any listening position with either left or right channel dominance depending on connections you make. Interestingly enough, when you have the gear to play 3 channel multi-channel SACD recordings, such as the Living Presence or Living Stereo Series. You will get a very wide sound stage, clarity, dimension, and detail not revealed from those recordings in stereo. Maybe get a cheap SACD Player and a 5.1 AVR?
