Be careful, sometimes when you bi-amp a speaker you change the resistence. For example, RBH T-1 is a 4 ohm speaker, however it is not 4 ohm if you bi-amp it. The tweeters are somewhere around 2 ohm and the mid-range woofers end up around 6 ohm. In addition, the power rating for the speaker is not the same when it is bi-amped. You should call the speaker manufacturer and verify the speaker specs under a bi-amp'd configuration.
