Hi,
I have a B&W 610xp powered subwoofer hooked up to my integrated amp (NAD326bee) It's a 500w 10" sub but despite its very low frequency response, I feel like its not loud enough. The volume control is already at max and it's still a bit low for me.
Since I have a spare integrated amp (Rotel RA04), can I use it to increase my subwoofer's volume? So the setup will be the NAD amp's subwoofer out will be connected to the Rotel amp, and then to the active subwoofer.
Now I know you only use a separate amp for a passive sub and there are dangers of overloading, but in my situation, I just want to add a little more volume to it.
Thanks in advance!
That is a small 10" sub. You can not daisy chain amps. You will get no more power, and damage the sub amp. The input is not designed to feed from a power amp. In any case your current sub amp would be providing all of the power, and your Rotel no power.
A couple of point in addition to experimenting with position. I suspect you have the bass extension switch set to A (-6 db at 20 Hz). Since this is a sealed sub, that will waste a lot of amplifier power as the a sealed sub has to be equalized at 12 db per octave. The driver will roll off far too high on a sealed sub, so you have to equalize.
So set the bass extension to B (-6 db at 25 Hz.)
You will have most output (sub will be loudest) setting the bass extension to C (- 6 db at 30 Hz), but then it won't be truly a sub as it will be rolling off at 45 Hz. On be it will be stating to roll off at 37.5 Hz and on A it will be starting to roll off at 30 Hz.
The higher the roll off the louder the sub will play.
Now make sure you have the sunb optimally phased with your other speakers. A phasing error will really reduce bass.
The next point is that this problem may not be the fault of your sub, but your main speakers. What are your main speakers?
Most of what is actually perceived as bass is actually well above sub range, in the 80 to 180 Hz area. A lot of speakers have inadequate baffle step compensation and are very deficient in this part of the audio range. The temptation is to play the sub too loud to compensate.
Often what I find on my travels, is weak in the wind main speakers and a ported high Q sub spreading a seeming audio gunge over the whole room. Really quite ghastly and not accurate reproduction at all.
And this is my last point, your sub is a low Q design and not designed to bring attention to itself, which a good sub should not. It will just give a subtle underpinning to the program.
Pretty much all European subs are that way. The reason is because so many European houses have shared walls. If your neighbor complains, the police can confiscate your entire rig. So European subs generally don't produce high spl in the last octave.
