Calculate port length w/ bend
jinjuku
jinjuku
Moderator
If the port does not provide sufficient surface area for the air flowing through it there is the possibility of port noise as well as port compression. If a driver is moving enough air that port compression becomes an issue SPL limitations can occur as is evident in many commercial designs. Basically, typical tube ports just doesn't have a large enough cross section for most subwoofers with large excursion.
Ok, I am going to do a slotted port design. Does WinISD automatically take End Factor Correction in account for it's slotted vent option?
annunaki
annunaki
Moderator
You enter the edge correction factor on the port description screen/tab.
