First has anyone out there built the a/v 3's ?
Yes, I have a pair with red oak veneer. Great speakers, tight bass and super clean and clear sound, not to mention great imaging.
If so any tips on putting the cabinets together ?
This is what I did since I'm like you don't have a table saw. Some of the braces cutout were off a lil bit.
1. Make sure you sand all the braces to the best even sides as you can.
2. use screws and glue since you don't have perfect cuts.
3. pre-drill holes before you screw those braces and sides together(also use titebond II glue). Also, make sure you the screws went deep inside the mdf so that you can apply some woodfiller to cover it.
4. attach the left side and the back first, then top piece. Make sure they're 90 degree angle.
5. then attach all braces together. Also remember to include the network or crossover on braces b and c.
6. now attach the right side and the bottom pieces.
7. Use caulking to make sure all the sides sealed and tight.
8. Apply the stuffing per GR-Research recommendation.
9. Lastly, attach you front baffle.
10. Maker sure everything is tight and secure. Use woodfiller if needed on those cracks and on those unwanted errors.
11. Choose your finish.
Have fun. Be patient and plan out everything first. You will love these speakers.
Al,
