Building speaker setup for $650 aus
Toli Chamos
What do l need to look out for to avoid bottlenecks and to make sure the sound quality is optimal.
tyhjaarpa
tyhjaarpa
Are you looking for stereo setup or higher? Do you plan to upgrade, if so, how? What do you wish to accomplish? How big your space is?
Toli Chamos
I don't plan to upgrade, I have no idea what a stereo setup is (If you could tell me that would be great) and my room is pretty small.
tyhjaarpa
tyhjaarpa
Stereo setup means 2 speakers that produce stereo sound. Music is mostly recorded in stereo. Movie sound tracks often are in 5.1 configuration. But as your budget is low and you don't plan to upgrade, stereo setup would be ideal.
Are you planning to use this setup for music only? For movies? With computer? Do you need a cd/blu-ray player to go with your setup? Or do you already have some / different budget for it?
Toli Chamos
I plan to use my speakers for music and gaming. Thanks for telling me that
tyhjaarpa
tyhjaarpa
So computer will be your source then I suppose? I dont know your prices but pair of Behringer Truth B2030A, B2031A or B3031A would be a nice speaker for budget like that.
Toli Chamos
What dac and amp would you reccomend for those speakers? Also, will l need to buy cables separately or do they come with the parts?
tyhjaarpa
tyhjaarpa
Those are active monitors, so you won't need an amp. You could use them without a dac as well from your computer. They will benefit from dac tho and some have reported that they have hum when connected directly to computer and using dac have got rid of the hum. ODAC for example would work in your situation. As for cables, I think they come with power cord so you would need to get cables for connecting between dac/computer and the needed cable will very on your setup.
Toli Chamos
Could l use any dac for these speakers and how do l check what cables l need? Btw bro, thank you so much for your help. It's greatly appreciated.
tyhjaarpa
tyhjaarpa
Pretty much any dac should work as far as I know. ODAC has good reputation and is really good for the price it sells for. For the cable you need to check what input your speakers has and what output your dac/computer has.
