Building new 2 zone system (small home theatre/outside)
Tony72
Relatively new to setting up AV systems. Just looking for some advice/input on my plans and confirmation on some things I have read about.
Equipment I am about to install:
Denon AVR-S750H
Klipsch Reference 5.1 Theatre System
Samsung 55" QLED
2 Bose Outdoor Speakers (151 Environmental) Impedance: 4 ohms
1. There isnt a issue using 4 ohm speakers in my second zone and 8 ohm system inside? Does the receiver need a certain setting for this set up?
2. I can bundle speaker wire but should keep the TV power cord and HDMIs separate?
3. Should I get a specific power strip for the receiver/TV ?
1/ No, not particularly....low impedance speakers with the lesser avrs could be an issue perhaps at high volume with main zone also in use....maybe.
2/ Generally you keep power cords separate, but many have nests of various types that never cause any particular issue, too. Set it up as best you can and see if you need to worry about it further than that.
3/ I like smart power strips keyed to the avr and other gear....YMMV. Just what are your expectations of a power strip, tho?
