building a good sound system for music and movies under 1000$
deeps
deeps
tryign to come with a good sound system that i can use for Movies and bluray for my lving room with high ceilings and open plan. roughly about 20 feet * 15 feet. the entire living is abour 25*25. but there is a middle partially dividing the living and dining area.
could you guys recommend something that has good sound and wont break my bank ?
thanks
deepak.
rojo
rojo
What components are you shopping for? Speakers? Receiver? Blu-Ray Player? TV? Are you in the United States? What city / state?
It's going to be difficult finding an appropriate subwoofer for such a large space within your budget. Would you consider used? Refurbished? DIY?
deeps
deeps
the living room has a middle wall that almost partitions the living space from the dining so about 15*25.
I have a nice 60: plasma. I am In Fremont , California USA.
I was looking to buy a speakers and an A/V receiver. so about 1500$ for receiver and speakers.
deeps
deeps
Thanks Boredsysadmin
how would these speakers compare to the hybrids you recommended?
Affordable Accuracy speakers from philharmonics.
deeps
deeps
thanks afterlife2.. this does look really good :)
I think am gonna go with them .. :)
deeps
deeps
sure will :) thanks.. how does the yamaha 720 comapre to the 730 ?
deeps
deeps
the yamaha 720 lists 8ohms
90W per channel (8 ohms, 20 Hz-20 kHz, 0.09% THD, 2ch driven)
105W per channel (8 ohms, 1 kHz, 0.9% THD, 2ch driven)
and the pioneer speakers mention an impedance of 6 ohms. would that be an issue? has anyone set them together?
afterlife2
afterlife2
You will be fine I have with no problems. No worries.
deeps
deeps
just came back from frys to try some of these speakers. they didnt have the pioneers in question but i tried some of the polks and they sounded quite nice.
I tested the Polk RTi8 and RTi4 and CSI4 and kinda liked them.
found a decent deal on polks-ebay to get 2 of those towers and 2 bookshelf with a csi4 center all cherry finish for about 740 $ delivered.
adding the NX-BAS-500 and the yamaha 730 would almost take me close 1300$ but am still considering because it sounded good and also has a nice cherry finish..
any thoughts ?
afterlife2
afterlife2
I would not choose those Polks over the Pioneers. If you want good Polk you need to find the older models and those are expensive. That is a great deal for that package. If you buy the towers alone they go for $360. Don't miss out they are great for the price I tell ya. Look at the pros reviews.
deeps
deeps
towers go for 360? are you referring to the pioneer speaker package or the polk rti8?
BoredSysAdmin
BoredSysAdmin
Forget about Polk. Hsu will provide better movie dynamics and hsu vft3hp sub will deliver outstanding bass.
Modified pioneer speakers are nice, but for 80% or so movies hsu would be better choices. I have heard both hsu subs and their bookshelves
zieglj01
zieglj01
any thoughts ?
They would not be my preference/choice, if doing a lot of music listening.
Now If you do like them - then that is what counts. It is about what floats your boat.
deeps
deeps
thanks for the suggestions guys...
i feel my living space will have issues running the wires for rear speaker s so am thinking i should go with just good 2 front speakers a center and a sub. now i listen to a lot of music more than movies so i think this might benefit with 2 .1 with a Sub option.
with this setup, what would be a good configuration to go for . if i wanted to stay in 1 to 1.5k range to get a AVR and the 2.1 plus sub speakers.
deeps
deeps
how does this sound for a set up
2 * YAMAHA NS-777 3-Way 8" Bass Reflex Tower Speaker
1 center Yamaha NS-C444
Sub - NXG Technology NX-BAS-500
with
YAMAHA RX-A2010 9.2 Network AVENTAGE AV Receiver
overall around 1500. does this look good for the money ?
